That would cause the brake lights to always be on.DustinZ wrote:Check brake switch on pedal.
Dustin
he is the authority on Z31'sAZ-ZBum wrote:That would cause the brake lights to always be on.
Problem is most likely related to the tail light sensor. It's USUALLY attached to the passenger side tail light housing. Remove the back panel. Look for a pink, purple, white, or black box about the size of a 17 pack of gum. If it's hanging upside down and/or full of water, that's your problem.
