z31 t3 wastegate is stuck
AN89HATCH
My wastegate on my t3 seems to stuck. As i try to spin it, so I used plyers to try to spin it, nut I eneded up breaking the shaft in half. So lukally there was another one in the junkyard, but it is also stuck. are these waste gates adjustable? becasue both i can not seem to adjust with out breaking it, and what is the stock lbs of boost on a stock z31, with the stock wastegate setting? thanks
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Time for an external wastegate
GoldZenkiS14
what are you spinning?? you pull the arm to see if it opens up or not.. im thinking you would need a boost controller to adjust boost higher then what its set for.. it should be set to like 7-10 pounds
ftrs13
Car: KATs
I dont think they are adjustable, I didnt have any luck with mine, and fortunately I didnt try hard enough to break mine.
I have one for sale if you break anotherSteve
ziggy682
Car: 1991 240SX Turbo
Dude, you don't need to adjust that. That is just for adjusting how long the rod is, it won't adjust boost or anything like that. Anyway, it will already be set at the right length to actuate the wastegate. The wastegate is set at 6psi stock.
AN89HATCH
i want to run 5psi :confused:
ftrs13
Car: KATs
there isnt much difference at 6, youll be fine
veilside180sx
their factory setting is 6 lbs of boost.
AN89HATCH
will walboro 255 fuel pump, stock injectors, and an 8:1 fmu be safe to run 6 lbs?
ftrs13
Car: KATs
yes, it will be safe
