Z31 studdering at low rpm
A home for 1983–1989 300ZX owners!
AZ89two4Tsx
Okay, here's the dealio. My cousin's 86 Z31 runs great and all, but when it's cold and at low rpm's, it studders a bit. This is when you're on the gas, in any gear. It doesn't cut out or anything, but just kind of "hesitates" if you will. This is on low throttle and if you give it enough gas, the problem does not happen. Any ideas? This is like a mystery problem. It idles fine.
Oh btw, it's a 5 speed and has about 75,000 original miles on it. Digital dash if that makes a difference. Almost every possible thing you can think of has been changed, including almost every vacuum line. Since I'm in town with him, along with changing the oil, we cleaned the maf. He's thinking an oxygen sensor now. But it doesn't seem to be throwing any codes.
Anyone have any ideas? I'm stumped, he's stumped and everyone else he's talked to is as well.
DoctorRobert
Car: 1986 Nissan 300zx, 1985 Nissan 300zx, 1987 Nissan 300zx
I have the same thing with my '85 300zx. I just ignore it till it warms up. I'm used to old cold natured cars...
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
This seems more engine related than transmission related. so check the compression, spark plugs....
AZ89two4Tsx
Car is mechanically perfect (in theory).
Plugs, cap, rotor, etc.... were already changed.
Perrenial Badass
Car: 1973 240Z, 1986 300ZX, 1987 300ZX, 1984 Corvette
Sounds like lean surge. Can you get your hands on an 87+ ECU to swap in for a cold start test?
Oh... and NA or turbo? What's it idle at?
AZ89two4Tsx
No, I can't get ahold of an ecu. I'm in Missouri right now, and I live in AZ.
N/A motor. Idk how I forgot to mention that, lol.
And the idle was adjusted by a mechanic, I remember him telling me that. So it should be oem spec? I haven't driven it so idk. What SHOULD it be? When he got it adjusted, it was at 500rpm, so they turned it up.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I'd have a look at the aicv and the mas
Perrenial Badass
Mine sat at 850rpm without accessories on. It went up to... about 1000rpm, maybe 1100rpm with the idle up, can't remember exactly since I haven't drove the f***er in forever and a day.
If everything else checks out, I could lend you an 87NA ECU to test if it's lean surge.
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
Exhaust or intake leak. Check vacuum lines. Check manifold bolts.
AZ89two4Tsx
Hmmmmm....I'll be sure to let him know and check these things out. Hopefully it's an easy fix.
Thanks guys.
Return to “300ZX (Z31) Forum”
