evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Sep 25, 2004 7:41 pm
did a little digging (the M30 is kinda rare) yes the M30 had an R200 but the housing is about an inch longer than a standard R200 due to an extra speed/ans sensor, not sure if they has lsd or not, I've found conflicting info, it might have been an option? easy enough to find out, put your car in gear and jack up the rear, try turning 1 wheel, if it turns it's open if not it's a LSD, if you pop the halfshafts compare the ends that go into the diff if one is longer than the other then you have a VLSDif it's open and your wanting to upgrade a standard R200 LSD carrier will bolt in you'll just need to reuse your gears (beware there are 2 diffenert ring gear bolt sizes used in R200's(10mm & 12mm))
