Z31 problems
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
Mikel
I have an 88 300ZX NA. It won't rev over 2000rpms for some reason. If you try to give it more gas, it seems to bog down like the engine is flooding. The spark plugs, wires, cap, and rotor are all new. Any ideas?
NISTECH
probably air flow meter . unplug it and rev the engine should rev the same as it did when it was connected. if so i would say airflow has taken a trip south.
rich3zt
Car: turbos
i had the same problem in my 86 z turbo. what i did was change the fuel filter (8 bucks), and plugs and wires.
if its not that it could be the fuel pump. try injector cleaner first. but definately get the fuel pump checked out
george rothon
Car: cars,karate,motor sports
Yip it's the A.F.M. at fault ,I had the same problem and replaced the air flo meter and it was cured straight away ,it took less than 5 min.to get the car running properly.So save yourself the time and trouble looking for things that will just upset and confuse you and get a A.F.M. and it WILL be sorted.cheers
rich3zt
Car: turbos
ohh my bad, i didnt notice that you already put new plugs and wires in.
Return to “Datsun Z Forum”
