Z31 pistons in an SR20
scrubnick
Car: browsing forums, meeting people
Is it possible to use Z31 pistons in an SR20? I know the Z32's will fit with a little modification, but what about the Z31's? Would it work and have lower compression? Is it just plain impossible?
bigtom
hmmm. round hole...round part. seems like it would fit but not sure about the compression.
97nismo
Car: tunning
I guess it would depend on the bore. The Z32 pistons require a .020 overbore making it 86.5mm IIRC and they need some modification to the rod end to fit the piston properly. NA Z32 pistion will give you around 11:1 CR and turbo pistons will net you a 9:1 CR.
