Z31: No Sparkage...
A home for 1983–1989 300ZX owners!
91300zx
Car: 1991 Nissan 300zx 2+2
My brother's z31 wouldnt start so he replaced the spark plugs AND the coil pack. Still no charge... What the hell could be wrong? I am thinking it may be a connection to his alternator or something.
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
What makes you think the alternator? I seriously doubt that. If the alt went out, the car would still run on the battery.
Most likely it's the crank angle sensor in the distributor, or the ECU is fried.
I'm also making the assumption the cap, rotor, and wires were checked/replaced. Right?
91300zx
Yeah so how do you go about fixing the crank angle sensor?
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
the crank angle sensor is under the ignition rotor (remove cap/rotor/dust cover) i believe you will need to remove the slotted wheel from the shaft and the optical sensor itself, you may need a torx set
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
ignitor? ECU? and the CAS I believe comes only on form of a new distributor?
Return to “300ZX (Z31) Forum”
