Bernard wrote:A z31 maf is not good for 350hp in stock condition. With 12vdc connected they will output 1.6vdc without the engine running. It will not work properly with any ecu other than a stock z31 ecu.
thats what the safc is forQuote »You can install a resistor to bring down the voltage to what your ecu likes to see if you want to use one. The 89-94 Maxima is good to 350hp and has a normal voltage output that will work on your ecu.
Bernard[/quote]you may be right, i dont know, but it doesnt make sense to me why the voltage output would be the same, but is still able to support more hp. usually you give up resolution for a wider range of airflow readings, assuming max voltage is the same. are you saying the maxima maf reads a higher max voltage than other nissan mafs (5v max, I believe)?
