kasilvia »
https://forums.nicoclub.com/kasilvia-u32122.html
Tue Dec 12, 2006 4:19 pm
Okay, so I have an 87 N/A Z. This car has been a great DD while my 240 is down for "overhaul", that is up until now. I no longer trust this car any further than I could throw it. I am hoping that someone has experienced what I am going through with this car before, and could nudge me in the right direction. If you think you can help, please read on, otherwise thanks for reading this far.Synopsis: Car starts and drives normal without any warning of what is about to come. Drives fine for a roughly 25 min span of time. Some of that time at interstate speed some sitting in traffic, and some just parked running. This is my typical commute home from work, except this time, while sitting on a slight incline at a stop light it happened. It started with a slight raise in idle, followed by the inability of the car to maintain idle. With the gas pedal fully depressed, the engine sounded like it was bouncing off of a 2300rpm launch controler, wild exhaust explosions and a tachometer that was jumping around feverishly between 100rpm and 4000rpm. I try to lift the clutch to ease the car forward in hopes of limping my embarassing pyrotechnics display on wheels home, but the car has absolutely no power to do so. It will give up a good fight with the pedal on the floor, popping and stumbling while sulphurus smoke pours out of the exhaust, and then begins to smell of burnt metal. After maybe 40 seconds of fighting, the engine gives way and dies. I attempt to start it back, hoping it was just a freak occurance, it just spins and spins. No start. I wait as traffic piles behind me, still no start. Twenty five minutes later, a tow truck arrives, just for grins, still no start. Twenty more minutes and $85 dollars later, car is coming off the rollback. I dont know if by habit or what, I hop in, twist the key over, and bam, she fires like off the showroom floor, then quickly thereafter dies, only much less dramtically than before. One more crank to assure me that she deserved to be trailered to my shop, only to be smacked in the face when she starts and drives into my shop. I can no longer diagnose my problem because it now has run for over thirty minutes while I waited for it to die again. This is the third time in roughly 12000 miles (over two years time span) that it has given me the dramatic death and then refused to start, only to start after roughly 1 hour of sitting. Any ideas, or testing data for components such as the distributor (more specifically the crank angle sensor), MAF, or any other part that you recommend I look into. I am wracking myself trying to figure this one out, and it never dies on me when somebody is with me to help diagnose when it is dead (i.e. to turn the engine over to check for spark) so I have no useful data as to what system the problem lies in. Thanks for reading my book,Luke
