Z31 doesn't go over 25mph
A home for 1983–1989 300ZX owners!
MarineVet
Car: 1988 300zx non turbo auto
After driving for awhile my transmission started slipping. I thought it was low on fluid so I put a quart in it. Then after driving for awhile every time I went over 25 mph it started to sputter and wouldn't go over 25mph. I noticed I couldn't put it in overdrive when this happen. The transmission was rebuilt last year so I'm totally clueless on what the problem is. Can anybody tell me what's wrong?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
For clarification, if you put the trans in neutral you can rev up to red line? if so, whatever it is it's in the trans and or torque convertor.
MarineVet
Yes if it put it in neutral I can rev it to redline. It only starts slipping when I drive it for more than an hour. But the thing is sometimes it won't go to redline when the overdrive light doesn't come on.
G-E
Car: 1. 1987 300zx Turbo-swap, SF interior, koni rallisport springs/struts, msa swaybars
2. 1997 Sebring coupe
3. 1987 300zx 2+2 becoming a caged racecar with RB swap...
Try a fluid/flush/filter change on it first... it may behave wonky for a week after but it should clear up
If it's still slipping, either you need a rebuilt/new valvebody because it's too gummed up, or you need a full rebuild to tighten up bands and such... unfortunately that can mean spending money on fluid more than once as you go for deeper service, if any previous step didn't fix it :\
Return to “300ZX (Z31) Forum”
