z31 digi dash swap in d21
SxMachine
Car: Im on a horse
Cant seem to find any writeups on this swap. Found this on yotube. Apparently he swapped the dash while it was still a 4cyl.
[youtube]http://www.youtube.com/watch?v=dOawpFMKbls[/youtube]
KA24ET_D21
Car: 1991 nissan D21 hardbody
KA24E
it can be done. ive swaped a 240sx cluster into mine. you just have to re- wire as far as that one goes. ive you want a z31 cluster on your 4- cyl that going to be tricky because the tach is set for a 6 cyl. the gear ratio for a v6 is diffrent from a 4cyl so the speedo will be off. youd have to get the oil press sending unit so the oil press gauge would work in the cluster just small things like that.
StephenG
Car: 93 Nissan Hardbody 2wd KA24E 5spd
87 Nissan 200sx CA20E 5spd
I just died a little inside knowing mine will never be that nice.
SxMachine
Car: Im on a horse
Well it looks like i'm going to my local jy to snatch a few zx dashes this wknd. I must know the secret!
KA24ET_D21
KA24E
get the speed sensor out of the trany. and the oil press sender out of the block.
longtooth
Car: 89 d21 HB
StephenG wrote:I just died a little inside knowing mine will never be that nice.
Me too
