tyrannix »
https://forums.nicoclub.com/tyrannix-u27595.html
Sun Nov 06, 2005 7:19 am
yeah, thats the thing tho, i have a full z32 swap (front rotors, calipers, rear rotors, calipers, knuckles and ebrake cable) and the front and rear S-to Z brake stainless lines (projectsilvia i think)
but the z 32 fronts are too big for my wheels. so i can get rebuilt Q calipers for $45 +shipping each, or rebuilt Z31 turbo calipers for $90 + shipping each
my choices are
A. 18mm wheel spacers
B. get wheels with more clearence
C. get front inboard mounted piston calipers ( Z31 and Q445 looking like the best choices)
i feel safer not using spacers, and i like my rims alot, so a and b are out
i can sell my Z fronts no problem...
my question was really: do Q and/or Z31 calipers use Z fittings (so i can use the stainless lines i have)
sidenote, ive read a few articles that actually tested a front only swap vs stock brakes (using teh same type pads)and the front swap only did have a faster deceleration, but because teh bias shifted so much, the actual total stop distance was something like 11 feet more for the front only swap
its like like this chart (i dont remember where i read teh article tho)
so i am doing the rear Z brakes, i just need to find a different solution for the fronts... wether the Q45 or the Z31 will do me better (ill worry about bias later)supposedly teh Z31 have more piston area, with 2 bigger pistons mounted inboard, but i need to verify this before i go buying more brakesthats why im asking if anyone has done it, i cant really find straight answers elsewhere (the archives didnt really help much)
edit> and im talking about the 88 gen turbo z31, it had 2 pistons inboard slider type
edit2> and the correct z32 MBC will go right on an s13, an s14 needs to bend the hardlines a bit
