I see, thought two sensors were the same one. I've only had my Z for three months(its even my first Nissan) so I'm still learning.evildky wrote:, the temp sender int he intake manifold serves only the gauge, I left my stock one in place as I intend to return to stock soon, the ecu recieves a temp signal form the chts to determine a/f for cold starts and such, the chts is located on the front of the drivers side ehad, at the base behind the timing cover backing plate, you can kinda get to it at an angle next to the thermostat housing
Thanks Badass, I'll check it out.Perrenial Badass wrote:I have a Sunpro temp gauge in my 87 since the stock one gave me a scare (almost boiled the motor and the gauge didn't show anything). I redid a section of the stock wire and put in a new sensor for the stock gauge, then tapped the plug like evildky did on the driver's side (it's where a second temp sensor goes for the injector cooling fan I believe). Built a pod out of one of my AC vents. I have the analog gauges though, so I haven't felt the need to upgrade anything else there yet.
I really like the Autometer gauges. I've read a few things about how they can become a bit inaccurate and read a tad off over time, but that is an easy fix. Melspace02 has most of their gauges if you want to search for interior pics of his car.
Can I still get that pic???Perrenial Badass wrote:The one I was talking about is exactly where the stock temp sensor is. Only on the other side. You should see a sensor with two wires (I believe) in that location, or a bolt that plugs the hole. I can get a picture if that would help you.
And leave the timing belt cover alone. At most, modify it, but don't remove it completely.
I looked at the service manual, I downloaded the service manual a month ago. But Badass offered me a nice color pic of the exact location. might as well take advantage of the nice offer.
