Pitts »
https://forums.nicoclub.com/pitts-u231537.html
Sun Dec 07, 2014 9:17 am
So Friday I had an extremely lucky call. Some 'special' person decided to slam on their brakes to be able to make their turn in the highway. Started slowing down a bit and then I hit a patch of black ice. Wheels locked up, rear end kicked out, all the fun stuff. Ended up doing a 360 into a ditch (luckily there was a bend in the highway). Barely missed the idiot and missed some posts. To top that, I was able to drive away and everything/one was good. So I decided I better check into ABS potential for my 84. Upon looking on RockAuto, it says the 89 had ABS. This true? If so, I'll be on my lookout for all the parts for the conversion (during this fall anyways). And other than the module, ABS unit, speed sensors, and some new lines to add length, would I need anything else (such as specific axles for the sensors to take their reading? And would they fit in an 84 GL? Thanks for the help!
And I did do some searches under z31 and ABS with no luck.
