z31 5 lugs onto s13?
nisstek2
Car: 1990 s13 coupe-finally running
just as the topic says, will the z31 5 lug hubs work on an s13? if needed i have access to a bearing press if they work and its the easiest way..i have searched and found a few threads on how to do s13 5 lugs on a z31 but its mostly swapping control arms and such..anyway thanks for any info.
nisstek2
umm...well...anybody have an idea of where i can get hub bearing specs? maybe i can compare sizes and just press the 5 lugs out of the z and install them on the 240 and vice versa on the 300...
nos487
Car: 86.5 nissan V6 5speed truck
Whats up Billy? The hubs are diff. the z31 has tapered bearings and are not sealed. The s13 uses a sealed straight bearing. I have a set of z31 hubs and brakes in garage if you want to see difference. Jay
