Z24i vacuum
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Andrew720
Car: 86 720 2wd z24i
Ok so i have read all the posts about emission delete stuff but my question is, is it the same for my 86 z24i? Everything i have read has been about carbureted engines and nothing has mentioned if the throttle body injection engines are done the same way, so if someone could just let me know if it is the same or if someone has done it to a tbi motor and how it responded i would very much appreciate it.
Thank you -Andrew
ARTadpole
Are you asking, " is it ok to remove the same vacuum lines on the throttle body (Z24i) engine that you removed on the carb engine."
Return to “Datsun 720”
