PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Tue Aug 25, 2015 8:57 pm
I usually advocate spinning the engine by hand (socket on the crank pulley) just to verify that pistons wont hit valves, but if its actually running, I doubt that's your problem.
If you rotate your dizzy so its hard over in one direction (such that it runs best), then yeah, you're probably off a tooth there.
