z24 transmission the same as a ka24e transmission?
anthony4x4
Car: 1995 nissan hardbody
searched butnuthin need to find out my transmission went out and i can find a hardbody in the junkyard with a manual trans.
ketshy
Car: 1990 300ZX 2+2
I believe the bolt pattern is the same, but whats it going into? I'll be more help with more information.
anthony4x4
its a 1990 hardbody with a ka24e 2wd
ketshy
Car: 1990 300ZX 2+2
Should work like a charm then. I have a four speed that should bolt up, but its an older style transmission so I believe the shifter is different and its shorter. If you go to the junkyard just take a measure tape with you and double check on length, you may need to grab the drive shaft too.
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
FS571C they are the same trans.
rps13srsc
Car: 96 240SX Base Model
what about the auto trans for a hardbody. does the 240 auto work
