seang »
https://forums.nicoclub.com/seang-u122444.html
Sun Apr 25, 2010 7:05 pm
Wow, someone is actually going through with the weber carb swap, is that the Nismo manifold? Are you using stock ignition and ECU?
What kind of engine parts are you using? I would suggest forged pistons and ARP head studs for the nitrous, but the stock rods should be good to 300hp or so (rule of thumb). 200hp NA before the NOS is optimistic.
