formerseal5 »
https://forums.nicoclub.com/formerseal5-u229276.html
Tue Dec 24, 2013 9:01 am
I have checked and double checked both the block and the head. I did have someone at the parts counter for Nissan tell me that sometimes when using a head that has been rebuilt, that it should be shimmed. Both the block and the head are from separate machine shops. I have torqued the head to specs and followed the sequence to the letter each time I have put it back together. I did attempt to use a gasket that had previously been torqued. Now that the head is off AGAIN, I will double and triple check everything again before wasting another head gasket on it. I have never heard of needing a shim for the head gasket, I mostly work on Chevrolet's. But I'm doing this as a favor for my Dad, he really couldn't afford to get this work done otherwise. I do appreciate your response. Any more suggestions?
