breadbox »
https://forums.nicoclub.com/breadbox-u49113.html
Sat Feb 18, 2012 10:19 am
Here's my take on the two options.
V8. Motors sets are easy to come by and can be cheap especially carb'd 302's. You will need custom mounts and probably a shortened driveshaft if not just a custom 1piece. The power might not destroy the rearend right off the back, but realize the stock truck has like 140hp. So rearend upgrade would be a great idea. Nis720 is bout to throw in his new rear which looks so nice.
With the v8 the whole oil pan and exhaust clearance and whatnot are things you will need to figure out, cuz IDk.
With KA if you use a truck's KA24e it will already be rear sump oil pan and the trans will bolt up but it might be at the wrong engine angle. that's why I say use 240sx harness, ecu, intake and stuff from the 240...mostly cuz its easier to find a parted out s13 240sx than a parted out d21. if you can get it all out of a truck use it.
Now the things KA's do well.... They seem pretty idiot proof motors if you understand basic motor theory and they take low boost stock surprisingly well. Also if you build the motor to handle the boost better you can up it to like 12-14 pounds of boost on a t3/t4 and have a crazy fun truck.
You could also try to do a DOHC KA but the simplicity goes out the window as compared to SOHC.
Oh and going from carb to efi its a good idea to change out a gas tank from a newer truck that is the same size and shape but that has baffling.
use a KA trans out of a truck not sure if its the same as the 240sx. but probably. so drive shaft shouldn't need replaced.
