have a 1986 nissan nomad, vanette c22 with a z24 engine in it
just replaced the points and cap and having nothing but problems with it
due to were the engine is i can't get a spaner or socket on the crank pully to align the rotor to highest point so trying to do a reverse gap on the lowest side sort of works for a while then it starts missing again.
have now advanced the timeing on the distributor to compensate for the missing and runs better but still miss under acceleration. have check all the leads with a muli meter and are with in specs.
i think i may have a vacum problem and this is causing the problem
also the engine has a emition control system on it called AEI with heaps of vacum lines coming off the carby and the air cleaner can i buy pass all this system and just use the vacum line on the distrubtor when i got the van half of it has been disconected and whats left of the pipes are all split etc
any info be great
thanks
kevin
