burtandurny101 »
https://forums.nicoclub.com/burtandurny101-u257739.html
Thu Dec 03, 2015 11:48 pm
As for the air filter..... I've never had a problem with that lil guy except the cheap clips rattle off and I tie it down with a shoelace... Zip ties could work too. I have run it without and with the air filter on, it makes no difference as long as the element is clean. a Taller element is available with the same footprint so its as simple as taking off the clips and putting the new one on.r
Do not even pretend to tune the carb until the timing is set, use the factory setting to start, and run through the ignition wires, plugs and test/replace the coils. Also inspect/replace the cap and rotor.
Check voltage across battery while running engine, bad electrical input = bad spark.
Other than that, webers tune themselves
Set idle speed screw to whatever it says in the instructions, i think its set to when it first makes contact with the throttle shaft
Set Mixture screw to three turns out (I would start at 2 1/2)
Start it up.
If you are completely convinced it is running rich and screing in the mixture screw des not help jet down a size
