twoeightythreez »
https://forums.nicoclub.com/twoeightythreez-u62149.html
Wed Apr 11, 2007 6:28 am
It can make decent pwr with a modified Lseries head. It sounds like you already have an L-series head, so just go from there, put it together and throw it in, you can always upgrade the motor later.(any engine is better than none, right?)
The Z series will drop right into a 510, so if you want to build the ultimate Z-series motor, get a Z24 block (from a 720 pickup) and put an L-series head on it. You will have to modify the Z24 timing cover slightly, but it bolts on. The how-to is probably in this forum somewhere. The KA is nice but you do have to modify the car slightly....I think I've also read somewhere about people adapting KA24DE heads to the Z24 block....this makes for a bolt-in KA24. Search for it, I've heard of it being done.
