TrueSlide wrote:Iam searching for this block as we speak. I know the z20 is fully counterweighted and the KA head will slap right on. I have a couple questions, I have been searching and searching. My head is kinda spinning, need to take a break. But anyways from what I read the z20 block the way it is needs to be bored. Something about valve shrouding and fuel? Can anyone clarify? Also is it good to use the z20 Headgasket and headbolts on this?
I remember reading it requires a KA truck type starter. And anytype of flywheel/clutch combo.
Iam jotting all types of info down, and planning ahead on what I want. So I can get started as soon as possible. I already tore the cylinder head down tonight and ready to get started.
TrueSlide wrote:While surfing the internet trying to find which veichles have the z20. It came down to two different models of the z20. Any real difference in the bottom ends and the ability to use with KA?
1983 - 1985 Nissan 720 Pickup 2.0 (Engine: Z20)1980 - 1981 Nissan 200SX 2.0 (Engine: Z20E)
What you want is the block from the z20e(200sx front sump engines, truck engines are rear sump).
Valve Shrouding: when a valve is to large for the surface area of the piston, it will prevent swirl or lack of swirl for atomizing fuel to air. Shrouding by definition just means to cover.
Now if you want to keep the high rev of your 2.0 litre, without boring to 2.1 or 2.2 (which would probably I am assuming would be the maximum bore).You can order z20 valves (I believe)and use them on the KAE head with some actuall work done to the KAE head,(porting and welding.) Or use the Z22valves which I believe is the maximum that you can use for the 2.0 before valve shrouding... (Now some one stop me if I'm wrong)....The only differences that I notice between the NAPSZ head and the KAE head is that the KAE uses a lifter assembly while the NAPSZ head uses a rocker arm assembly. Hiegth between the 2 heads are the same......If you would like to bore instead, and keep the KAE head with the original valves the way you would want it you would want to get an L20B bore KIT, which I believe the maximum offered is 2.2 litres, But a 2.1 litre or better will be needed if you decide to stay with the KAE valves.Use the KAE gasket on the Z20 block.Use all the NAPSZ timing chain assmbly (sprockets and chains) for the KAE head.Use the Z20 head boltsI may have missed something.......
