Seishuku »
https://forums.nicoclub.com/seishuku-u28745.html
Sat Dec 25, 2010 11:13 am
It's fuel and spark, unless the distributor has the vacuum advance can on it.
And yea, you would need to do a lot of work to the fuel to run that big of a cam.
Most of the older turbo engines had a hotwire MAF instead of a flap type meter, but no one has ever mapped out the ROM on those ECUs, so I really doubt you would ever be able to use a larger mass flow meter on it.
Your best bet would be to go to a standalone system, like MegaSquirt.
The stock management on those engines just isn't very tunable, though you could very well use a stock system off another engine, like a KA or SR. It would take some work, but it is doable.
