if your using the oem dash plate there are only two brackets that you need to take off. they are the two metal brackets on the side of your factory radio. just unscrew those and mount them to the new dash plate and radio.richwhat425 wrote:sorry if this has asked b4 but I want to know what I need to install a z110 in a 2.5 stock radio a/c? I bought the OEM dash kit to get that factory look but not sure if i need brackets and (if i do) which ones? I'm gonna try installing it myself so any input would be nice!
the vss wire i cant help with. but the bypass just follow the steps in this videorichwhat425 wrote:thanks for the input man....i did the install today myself....took forever but i wasnt able to find the vss wire...i read somewhere i was suppose to splice it into pin 30 but it was empty. a blue wire was right next to it...is that where i should put the vss wire.. do i stick the wire in the hole or splice them together then to it????...i also try to the bypass by movin the yellow mute wire over and it doesnt work either!!!!!pleasseeee helppp!!!!
