Z won't start
nathanyoung20
Car: 1990 300zx 2+2 NA
My '90 NA was turning on no problem while I was off at college and now that I'm home, absolutely nothing
the dash lights aren't coming on, but the headlights, high beams (the high beam light in the dash is the only thing that comes on), fog lights, taillights, and interior lights are all working
when the key is turned it doesn't even attempt to crank, absolutely nothing happens
any help would be appreciated, thanks!
aroche25
Car: 2007 Mazdaspeed 3 GT
Looking for a Z32 Slicktop
Try checking fuses inside the car by the false pedal and in the engine bay. What kind of shape is the battery in? Try and get a voltage reading if you can.
nathanyoung20
the fuses look fine to me, but i don't currently have access to a test light or multimeter so i can't get the actual voltage readings. the battery is brand new so i don't think that is the problem. i thought that it might be the main fusible link, but when i pulled that out, it looked/felt alright and my taillights and brake lights only work when the fusible link is in, any other ideas?
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
Have your battery tested/re-charged. If it has been sitting for quite a while, it's probably low.
