Z-Tube
Beezer
Car: 2007 G35X
Ok, bare with me here guys as Im trying very quickly to get a handle on the whole intake thing. Eventually I am going to install an intake but understand I should wait for one with a heat shield (unless I go with Stillen). My question is, if I decide to wait, should I go ahead and order/install the z-tubes in the meantime? Would I be able to use the z-tubes in conjunction with an aftermarket intake or would they become redundant?
Thanks in advance!
G_whizz
Car: 2010 G37 Coupe Sport
Do it all at once... JWT popcharger has a heat shield.
Beezer
Car: 2007 G35X
G_whizz - does your car have the dual intake setup?
smockers83
Car: 2006 G35 Coupe
If you order the Z-tube with the POP Charger, you can get a discount on it at http://www.everythingg35.com
But no, if you order it now or whenever, the Z-tube will not become obsolete if you get a different intake.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Is there a Z-tube for an 07 Sedan???
G_whizz
No I don't ... I have the Coupe, but whether you have 1 or 2 Intakes... they should be the same as mine.
Someone correct me if I'm wrong.
If I were you... just order the dual intakes and Ztubes all at once and put them all in at the same time for less hassle.
Joe at everythingg35.com is VERY helpful.
Beezer
Car: 2007 G35X
Did some more looking around - I dont think JWT has a set-up for the dual intakes. Looks like everyone is still waiting for it.
