Z-Tube Ping ?
NumbNutz
Car: G35 Sedan
Picked up the Z-Tube for my 06 sedan..Now I hear dieseling, a pinging,or a knocking sound, like when you need more octain. I did fill up with low grade last fill but I often use low grade or 92. Todays car so dont "need"high octain they just want there warenties to last I thought. Anyone have this hapen with improved air flow?
btr2ltr
Car: 2005 nissan titan se, 1991 eagle talon awd, 2004 mitsubishi evolution gsr
use the lowest octane gas you can without pinging, otherwise your power will drop as the ecu pulls timing due to knock sensor activity. newer that have premium fuel recommendations are not for warranty reasons, they are recommended because that is what the engine and ecu configuration was designed around. use good gas-make more power
NumbNutz
Car: G35 Sedan
Wow. Thanx for the info. Sounds valid.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
I use a brand name Prem. in my Sedan.....no pinging.....can not stand pinging.....Prem. in my cobra, and middle grade in my pathy. Pinging is not good....is the sound of wear.
