Hey guys, so if you havent read my build thread then you dont yet know.
I took my car to a shop called Dr. Z Tuning in Westminster Ca. (AKA ZKingNation) or whatever he wants to call his shop for the day...
I took it there with the intention of getting a tune up on my 1990 300zx 2+2 NA with 80k miles. On the way up there, the crankshaft bolted counterweight decided it was claustrophobic and wanted to escape....So i decide to have a TT Swap done. After talking with John (real name Samual), we talked about a STOCK TT swap for appx $5,000.(parts and labor). I would be making payments on this. During the next week i decided to upgrade some things while the motor was out... bigger turbos, FMIC, injectors (555 nismos ) and JWT computer witha couple other odds and ends... new total close to $8,000... Here starts the lies... I get a call a couple weeks later (2 approx) saying the motor is rebuilt and ready to go in can you bring up your next payment so we can get the rest of the parts we need for the tt swap...
So i get to westminster (2 hours away) and find "my motor" sitting exactly where it was 2 weeks ago, and i asked.. oh its ready? no we are gunna start working on it today... ok whatever... they are letting me make payments...
another 2-3weeks go by and its supposedly close to being done.. it will be done friday ... i come up friday... motor not in car, more lies.... it will be done next week... come up next week still not in the car... more excuses more lies...
Finally the motor is in the car starts.... we go to test drive the car and pulling out the parking lot i hear clanking... i say whats that chattering,... he says oh its the 6 puck clutch.. u not shifting right... it continue two more blocks...he says go back to shop...
get the car on the lift to find out that the parking lot is littered with my drive shaft bolts which were not installed properly...
i should have packed up and left right then and there... but he says... no ill fix it..ill make it right... (MORE LIES)
So we get the driveshaft on right... and go for a test drive.. car warms up... clutch starts slipping past 3000 rpms... i say... is it the adjustment on the clutch(behind the pedal) he says no its transmission (me not knowing much about cars at this time didnt realize that when a MT goes bad it grinds not slips) So he changes transmission (allowing time for clutch to cool off)... it gets to a point where i can drive it home... except i dont even make it home before the car sputters to a stop on the side of the road... had it towed to my house to find the center idler pulley had snapped causing piston to hit valves
I call and complain complain complain.. he has the car towed up to replace motor again...
I come up to check on the progress and he shows me a piston with a hole in the side of it saying it was my fault for letting something get sucked into the enigne.. i call BS and decide **** u im not arguing fix my s*** and be done...
I come back a couple weeks later doing same thing clutch slipping... he says come back in 2 days... same thing again... finally i say im done.. get the car driveable and im outta here...
Meanwhile noticing the use of oil hose for fuel line... jerry rigged bolts too long for ANYTHING... hard fuel lines not bolted down... etc...
On the drive home... the car throttle sticks open... have to shut the car off to prevent over rev...
Get car towed home and open up the throttle intake pipes to find a bolt wedged in where the throttle body butterfly is (he dropped into the intake pipe)
So i start taking things apart further... finding jerry rigged lines and bolts everywhere... tools left in spots on the car... just an absolute disaster.. my nismo 555 injectors were not nismo 555 injectors that i had paid for... they were stock NA injectors (2 of which were not working)... i pull ECU... thank god...its got a JWT sticked on it.. hmmm lets just double check and call jim wolf....it is a JWT designed for modified intake only! another ripp off..
During all of this.. tons of things were found wrong..to include one turbo wastegate hooked up wrong ... missing trim pieces, and dented rims...
Lots more stuff... too much to list in this for right now (see build thread)
So since then i have contacted the California Bureau of Automotive Repair... who basically looked into it and said only thing they can do is file paperwork...
Contacted the BBB (they now have an F rating)
http://www.la.bbb.org/business-revie...r-CA-100115592
And i am posting on craigslist every ten days (which is where they post stuff alot)
http://sandiego.craigslist.org/nsd/ptd/3371946421.html
So let me beat some of you to the punch...please no s*** talking... i realize the mistakes and dont need a bashing for it... this thread is here to INFORM and EDUCATE others not to make the same mistakes.
Good Luck and Happy Z'ing
