tmeyer29 wrote:Hard to diagnose electrical over the internet. Try this, when the car is running. Wiggle around random wires and see the the idle changes. Also clean your PTU connections!
Good idea. Especially the PTU, if there is corrosion present that will definitely produce starting and running issues. Also a corroded CAS connection can prevent starting and cause missing. When I first bought my NA in April of 06, every connection was corroded and brittle. The car would not run right, no matter what I did. Could never thoroughly clean everything, due to the fact that the corrosion travels up through the harness wires. I ended up replacing the EFI harness myself, when I pulled the plenum for my injector replacement.
From my experience, you will probably need a new EFI harness, along with some new vacuum hoses. Hopefully your injectors are in spec as well.
