z NOT STARTING WHAT YA THINK????
300freekzx
Car: 1990 300zx N/A, 1992 Honda Accord LX , 1991 Honda Accord LX, 2006 M35 Sport
ok my car is not cranking here is the symptoms. All fuses are fine there was a blown shift fuse but got that replace but has me concerned. The lights all come on but the radio is not working, the clock is not illuminating, when I turn the ignition from alternator to the on position there is whining of the fuel system none of the dash panel lights illumanting. When I turn to start, there is nothing. I also noticed, however I do not think it has anything to do with the situation at hand but the electronic seat is running really sluggish. I have not had the battery tested to see if it is fully charged. I will do that later. Any insight is appreciated.
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
Its you're battery
if you're radio isnt wokring & seats feel sluggish its def the battery
put a charge on it, or replace it
300freekzx
Update the CCA was 227 after full charge CCA 447 therefore dead battery. Will be on the way to Oreilly to swap in the morning. They sell cheap a** battery for high prices!
car nut
Car: GT500.
Get an Optime battery. Definitely worth the price.
300freekzx
F/U I changed the battery with a new one but to no avail. The same problems persist. Could it be the ingnition not sending signals to the components that would operated by the switch. The clock is not working, radio do not turn on the lights on the dash panel are coming when I turn it to the on postion and the fuel pmp does not come on and therefore it is not sending a charge to the starter. Could this be right. Please Help.
DanDrath
Car: 1990 Nissan 300ZX 2+2 TT
double check the ignition fuse in front of the battery
z32pilot62
Car: 1990 300zx N/A A/T (Sold)
1990 300zx 2+2 N/A A/T-M/T
1972 Buick Skylark Custom
1970 Chevy Blazer (Sold)
1977 280z (Sold)
1991 Civic Dx (Beater)
Had the same problem in my Jimmy a week ago, everything worked until i turned the key to start it. All I did was cleaned and tightened the terminals and all was good. In cold weather a positive connection is very important. Just a thought, im sure you've checked them already tho.
