z delema
A home for 1983–1989 300ZX owners!
rbforsale
Car: '92 Nissan 240SX S13 vert ka-s
not entirely sure how to explain.hezitatz to crank,give it gas,it boggz.jumpy with gas in gear then boost then it just hauls azzand wont sustain an even idle,as though it where cammed.cant seem to find vacume/boost leak,getting gas cause when boost kicks in theres a huge black cloud,spark is good,no wet plugs.getting good reading from mafs...wondering if anyone has been there b485 turbo 5speed vmount hks bov exhaust and a bit of confusion?!?!?! just some suggestions,cause i cant think of anything else
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
sounds like it's running pig rich, chts can make the car think it's cold when it's not which makes it run rich, might want to look into the knock sensor as well, on the l-jetronic cars an open knock sensor also casuses rich condition
rbforsale
*sigh* this thing is realy starting to piss me off!
rbforsale
i tried unplugging the the mafs while the car was runningand the car just tottaly died.tried adjusting the distributer,it reacted but not badly.adjusted tps sensor while it was running reacted to adjustment,and flopped when i pulled the plug.all good fuses.getting proper voltage signal from knock sensors.curious,could an O2 sensor cause that... but im not throwing any codes?
evildky
06 Nissan 350Z GT
did you check the chts? could also be a bad ecu
rbforsale
chts is that the coolant temp sensor?
evildky
06 Nissan 350Z GT
cylinder head temp sensor, on the front of the drivers side head behind the timing cover
rbforsale
ill have to look into that, thanks for the info
rbforsale
car crapped on itself and burst into flames electrical firerip pos
evildky
06 Nissan 350Z GT
fuel leak? you knwo there is a free recall campaign for that
Return to “300ZX (Z31) Forum”
