allenms240 »
https://forums.nicoclub.com/allenms240-u128640.html
Fri Oct 08, 2010 10:00 pm
When you say it locks up, do you mean that it doesnt budge at all? As if you were trying to test drive it, but the caliper is stick on the rotor, not even allowing you to test drive?
I ran into this problem, It turns out I used the wrong bolts for the caliper and the bolt was actually stuck on the rotor, not allowing me to drive the car. So give that a check. However I;m not sure about the other problem your having with the other caliper. Did you get all the right parts, the z rotors, z calipers, and z to 240sx conversion lines?
