z brake e-brake question
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
i bought some z brakes off a 90 non turbo z. there a 26mm. i dont have the ebrake assembly, but i found someone local who has what i need. the only problem i forsee is that the ebrake assembly is off of a 92 z wich uses 30mm brakes. will that make a difference for me?
BrianHarte
Car: 180sx
I'm pretty sure the rears are all the same.
Please don't take my word for it though.
I think there were small differences in some of the bolts though... something about a tab somewhere...
Clawhammer
The rear is different. Isn't a big deal...
When you buy rotors just buy 26mm in the front and 30 in the rear. Done.
heartofaskyline
i already had the rear rotors turned. damn, o well it was only 20 bucks. will a 30mm rotor fit in the 26mm caliper?
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
They should, but the calipers won't be big enough to use all of the rotor.
Bumnah
Car: 1992 240SX, black. Bone stock.
all z32 rear brakes are the same.
26mm is for the front brakes30 mm is also for the front brakes
all z32 rear brake rotors are 18 mm thick.
heartofaskyline
thanks. thats all i needed
