Z-24 transmission interchange
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
720tillidie
Car: 1985 720 pickup, 1986 300zx turbo
what transmissions interchange with a Z-24? Ive read all over and havent found an answer. Ive heard a 280 Z/ZX turbo or non turbo trans. will bolt up. what modifications will need to be done with the swap? I just need a better gear ratio. can you rebuild the stock for high rpms? what are you running in your 720s as in transmissions? let me know something.
720tillidie
so no one has an answer?
seang
Car: Ford Fiesta ST
zerothread/445434
zerothread/442368 The owner of the truck in this vid says he has a 280z transmission.
This is what I know, oh yeah, a ka24 transmission (fs5w71c) will bolt up to a z24, the bellhousing pattern's are the same. There are some variances in the gear ratios with the different fs5w71c's.
PEZi
you could always swap out the diff... slightly easier
i don't know exactly what your goal is but the diff would be better in my opinion
seang
Car: Ford Fiesta ST
Some very nice axle info
zerothread/233955
720tillidie
what r u running? I want more power and a faster take off with out having crappy gas mileage, i drive it everyday.
PEZi
well right now i run the 3.70... but with smaller tires so its closer to 4.00
i want to swap it out for a 4.68 but we'll see
either way... your gas mileage will go down because you'll need more gas to stay 'at speed' once you get there
720tillidie
i expect the usual loss, but as long as its above 15mpg i think i could live with that.
PEZi
yeah... mine gets around 18 or so since i removed all the emissions stuff
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
The transmission I'm running came from an 80-81 A-10 I was told yesterday by datzermike on the 720world forum. He said it bolts up to the J, L and Z series engines.
Return to “Datsun 720”
