Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Tue Jul 01, 2003 9:50 am
No, don't use those. What you need is, well, "red rubber grease". It's ugly bright red stuff, usually comes in a small can or tube at Pep Boys/Autozone. Castrol makes a version of red rubber grease.
You CAN use just hydraulic fluid, but that is not recommended as it is sloppy and tends to run off the seals, whereas the grease stays put during assembly.
Edit: clutch looks good, they did include a TO bearing and clutch centering tool also, right?
