Your SR Top Speeds
Jala47
Car: 1999 Nissan Altima GXE
Please list if your SR and car have been modded or are stock.
Type of car and year?Which year SR did you have?What speeds did you top out at?About how long did it take you to top out?
and just some more out of curiousity..
What's your best 1/4 mile run?what's your best 0-60?What was the fastest car you draged?Which of these have you beaten?
If you think of anything else while filling this out just toss it in. :D
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Read the sig about the car, quarter times, and mods. I've taken my car to 164mph before and it was still climbing very slowly as my tires that are rated for 155mph started to shake :ylsuper . It doesn't take more then a minute from 80mph to get there, but I never really kept track at how long it was taking. I know my speeds through my Blitz SBC-ID III. Fastest car's I've beaten (at the track) are the Evolution, C5 Corvette, and Lightning. The rest of the cars I've raced either lost BAD or won by a long shot (drag cars).
rdoggins
Car: 93 240SX 2JZ/6spd
ItzGenX wrote:Read the sig about the car, quarter times, and mods. I've taken my car to 164mph before and it was still climbing very slowly as my tires that are rated for 155mph started to shake :ylsuper . It doesn't take more then a minute from 80mph to get there, but I never really kept track at how long it was taking. I know my speeds through my Blitz SBC-ID III. Fastest car's I've beaten (at the track) are the Evolution, C5 Corvette, and Lightning. The rest of the cars I've raced either lost BAD or won by a long shot (drag cars).
hey quick question off topic... how much boost are you running?
TruboostPerformance
160mph98 Nissan FrontierS13 Black 1996
GTS4-R
Car: my feet
s13 hatchredtop sr20det10 psi on t3/t4I went 105 in 3rd....140 in 4th.....and then **** my pants and couldn't go thru 5th....;)there were cars on the road (like 10 PM)should be able to hit about 175ish
240SXer
Car: 1995 240sx SE (2jz powered)
My 5th gear cut hits at about 135mph.
http://www.racingonthestreet.c...h.AVI
But I have 245/50R16 tires, which are decently larger than stock. At the track on my speedo I was traping at about 90mph, on the track's radar I was at about 102mph. So with that, I raced a 351 mustang up to 135 on my speedo (pulled like a mother when he hit 5th), so I took it up to about 145-150. Pretty quick.
ItzGenX
I am running 12psi for the one that asked.
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
The needle hit the reset button on the trip meter, and it was still pulling.
Anybody know what 7200rpm in 5th gear is with a Z32 rear diff?
Paul
Jala47
240SXer wrote:My 5th gear cut hits at about 135mph.
which SR do you have?
GTS4-R
Car: my feet
was that vid with the GT2540R or the T25?
S13 King
Car: cars, performance, girls
My car hits the 5th gear limit at 135 also.
I have a Z32 TT dif and I have MASSIVE TALL gearing. However it doesn't seem to make that much HP to get it there. That and I think the ECU still has the stock govt limit.
Phax
Car: Control dynamics
112mph baby!!! :ylsuper
<mumble, grumble> Pinche, worthless, freakin, governor... #@!$
GTS4-R
Car: my feet
stock governer for sr ecu is 120 mph (115 ish)
S13 King
mmwell when i was at 135 next to my dads bmw he said it was 135 when my car seemed to cut.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
eh, my car cuts at about 138 cuz i have taller tires and whatnot...stupid car :(...my car was definately pulling fairly hard when i hit that...i'm sure it'll go 150 if i got that rev limit taken off in 5th gear...
and who said they hit 140 in fourth? you werent driving a 240 then...or am i just retarded?
240SXer
That video was with an S13 SR20DET w/T25@8psi (stock boost). I hit 145-150mph @10psi at night (cooler = faster). All with the T25.
240SXer
With my big tires I can probably hit 135 in 4th, with a different rear end or slightly higher revs 140 in 4th isnt too far off. Very possible. With stock gears, stock revs, stock tire diameter, etc. SR can hit about 125 in 4th gear. Check out the video.... I shifted out of 4th at about 122mph and it wasnt even totally redlined.
GTS4-R
Car: my feet
ya i have a Kaaz 2 way slip and 17s with 225/45's....so my cluster is obviously not EXACT with my actual speed....it also only goes up to 110 but this thing was BURIED.....u can approximate the 10MPH intervals after 110
240SXer
My Turbo timer has a speed thingie on it (Greddy), I don't have it hooked up though. Which wire on the ECU would be for speed? That would be a nice way to measure speed. It's as inacurate as the stock speedo, but it will continue to read after 120mph.
Jala47
240SXer wrote:That video was with an S13 SR20DET w/T25@8psi (stock boost). I hit 145-150mph @10psi at night (cooler = faster). All with the T25.
What video? :confused:
240SXer
The video I posted:
That was only 135mph. I don't have a video of the 150mph. It was just a street race. That video was just me screwing around on the way to work.
(right-click and save-as)
Jala47
Oh damn I completely missed that post =(
I'll take a look at it when i get home
GTS4-R
Car: my feet
240SXer wrote:My Turbo timer has a speed thingie on it (Greddy), I don't have it hooked up though. Which wire on the ECU would be for speed? That would be a nice way to measure speed. It's as inacurate as the stock speedo, but it will continue to read after 120mph.
pin#32 its Yellow/Green (yellow wire, green stripe)
S13 King
well all my mods are as listed:1992 Nissan 240sx SEBlacktop SR20DET (from a 1994 180sx, I actually got the tail lights from the same car)Trust FMICTrust Type-S BOVTrust Profec-b boost controllerTrust DownpipeCenterforce Stage 3 clutchAuto meter: boost and A/F gaugesAGX coiloversGround Control springsURAS 3'' Titanium full exhaustFlexlite Dual fans180sx tail lights
240SXer
Fastest car i've dragged was a WRX that was in town for a rally event. We went from 40-120mph and he was actually able to toy with me and I was running 8psi, at 12psi he couldnt play as much but had no problem keeping up with me.
Car i'm most proud of beating is these dudes in a New porsche carrera, they pulled up next to me at a light and I revved up, they looked over like 'damn ricer this is a porsche' then when the light turned green we went at it, I beat him by like 2 cars. It was one of the greatest feelings ever. Smoking those dude was better than sex!
USDMSTALKER
Car: MY CAR
Does anyone know if a MINES ecu has a speed cut
wangless
Car: '02 MBP WRX
iirc someone had a mines ecu for a ca... no speed cut
SpeedFreak
95 240sx
SpeedFreak
95 240sxRed top sr172 mphafter 160 it was slow getting up there but I could have gone a little more but ran outta road/ballz. :D I was using a gps for the speeds and also using my Apexi Avcr to log the fastest speeds.
I trap 112 in the 1/4 with an unimpressive 13.1 This is on 275/40/17's Kumho Mx's. Lots of wheel spin, could really use a set of slicks but just dont drag race enough to justify the cost of rubber and rims.
240SXer
I was going to get some Kumo MXs, but I got nitto drags instead. I'm sure glad I did. I had kumo 712s before and they only lasted me about 8k before they were unusable. I think the nittos will last longer even with 100 treadwear because they don't spin so easily. Those kumos were like iceskates.
