NISMOdrift240 »
https://forums.nicoclub.com/nismodrift240-u4648.html
Thu Jun 05, 2003 4:47 pm
IMO, coilovers are a waste of money on a mostly street, daily driver. I am running the Eibach sportlines (2" drop) and its got a low enough crouch. just fine enough for speed bumps, and most steep driveways. although once i get some sideskirts, itll look lower, and ill have to be more careful.
as far as struts go (yes, get them at the same time) i was going to go tokicos, til the guy at the shop i went to why not go adjustable for $7 more each. so now i am running AGXs. 4 way adjustable in front, 8 in the rear. just enough so you can soften it up while you drive to work, then stiffen it up when you hit the track. i think the whole setup i got installed for like $650, and i couldnt be happier with it.
