Your opinions please!
FlogWaffle
Car: 1990 300zx NA
So yes, i am trying to do all i can to make my NA "faster." Before the s*** storm arrives, please note that i would LOVE to tt swap my car, or even just trade it for a tt, but at the current time...and probably for the next few years due to college that wont be happening anytime soon. soooo i basically have no choice but to lump it and try to eek out every pony i can in my NA. So far, i have an intake, headers, and full exhaust. (sounds great...moves slow) haha but i was looking at the z1 ECU upgrade.
Being Priced at $175, do you guys think this would even be worth getting for an NA? Its basically the only other thing i can do power wise that i am aware of (no...im not getting nitrous dont even say it haha) How much power could i expect out of a chipped ecu? :gotme
After that i am hoping just to make it a clean dd, that will last me for years to come before i decide to swap or trade it and go for a tt or move into the subaru game.
bbecker17
Car: 1991 240sx.... dead
1990 300zx tt jdm
im not to sure about the chip if i had to guess i'd say 10-20hp but i did just wanna say that theres only 1 replacement for more power and thats less weight so i'd say start tearing it apart!
Re037
Car: 1992 300zx 2+2 NA
id get a reprogamable socketed ecu instead, so if/when you go tt you ll be ready to tune.
Z31toZ32
Car: 1999 Infinity QX4
id vote that the only thing you get out of a chip on an na is a higher redline. shoot on a tt it doesnt even add power. all it does on a tt is make it run richer so you can safely run higher boost, which is where the power comes in.
FlogWaffle
Car: 1990 300zx NA
bbecker17 wrote:im not to sure about the chip if i had to guess i'd say 10-20hp but i did just wanna say that theres only 1 replacement for more power and thats less weight so i'd say start tearing it apart!
hmmm...i might just go for it, try to get everything i can out of it powerwise. But i have already started taking some of it apart actually! i'm waiting on my seat rail to get here from japan and ill throw my bride in there which is hella light compared the the stock seat haha.
a.p.barron
Car: 1985 300ZX Turbo
1991 300ZX N/A *sold*
What about a lighter UD Crank Pulley, lighter 1-piece drive shaft, or lighter flywheel? Those won't add HP, but they will definitely free up some and they will make your car more responsive.
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Z31toZ32 wrote:id vote that the only thing you get out of a chip on an na is a higher redline. shoot on a tt it doesnt even add power. all it does on a tt is make it run richer so you can safely run higher boost, which is where the power comes in.
Not true, there is a lot of fine tuning with the fuel delivery and timing maps that can be done by a real tuner. For a TT I'm saying.
For an NA, it's relatively pointless.
Z31toZ32
^ right. i was referencing an off the shelf chip.
300ZXttZMAN
you should do a weight reduction
vulcanrush
Car: 93 300zx n/a to tt
i've heard of being able to run higher boost with higher octane (100 octane vs 93 octane vs 91 octane, etc.), and methanol injection (same thing, really) --- i haven't heard of how much boost you can run being correlated with the air-fuel ratio setting in an off-the-shelf chip.
BigTDogg (MA)
The off the shelf chips fatten up the fuel curve so you can run more boost safely. It's a guess, as it's general for all cars, but it's definitely safer than running more boost on an OEM chip.
The best way to tune is with Nistune and you can tune each cell based on RPM and Load.
dantesdoom
Car: 1991 Nissan 300zx N/A
1997 Nissan Pickup
from one NA driver to another....intake and exhaust were your highlights....the car is fun and responsive, but its gonna be hard to get anything else out of it without serious cash
es.biggs
Car: 1990 300ZX 5sp NA
I'd get pulleys (underdrive crank, overdrive water pump) and a lightweight flywheel + upgraded clutch kit. Higher clamping force and better friction materials on upgraded clutches means a more firm clutch engagement - a difference you can absolutely feel. I wouldn't worry about the drive shaft until the center bearing on your stock one fails.
That's all I'd really go for man...any more money spent will be like paying for bread crumbs. Get the rest of the car in shape - there are tons of things to do beside engine performance. Subframe and differential bushings, upgraded sway bars and bushings, coilovers and adjustable control arms/traction rods/tension rods, wheels and tires, hids, and body mods/aero (front bumper, wing, rear bumper, whatever you like man). And of course there is always SOME maintenance you can do...fluid exchanges, fuel hoses, power steering hoses, fuel filter, brakes, the list goes on and on.
That's basically my gameplan...I'm spending some money on performance but not a whole lot. I really want to get to my suspension...this car is gonna be prime when I get to the TT swap!
PS - don't you have a hesitation problem? ;)
FlogWaffle
Car: 1990 300zx NA
es.biggs wrote:I'd get pulleys (underdrive crank, overdrive water pump) and a lightweight flywheel + upgraded clutch kit. Higher clamping force and better friction materials on upgraded clutches means a more firm clutch engagement - a difference you can absolutely feel. I wouldn't worry about the drive shaft until the center bearing on your stock one fails.
i don't know if i am going to worry about pulleys, and clutch and all of that. I am hoping to do a TT swap sometime when i actually have $$ haha, and i will have to get all new stuff then anyways so i think i will just hold off on that kind of stuff so i dont have to buy it twice ;) but i am thinking i will move into the suspension soon, after i get some rims + tires :D I'm kinda taking the same approach as you i guess, im trying to get everything else done and then in the end TT swap it and it will be nasty. but you hit the nail on the head with body work..haha some ***hole decided to beat my hood and both front fenders with a ball peen hammer all over..so they will all need a lil' lovin when my wallet allows for it.. (this was before i bought the car...sadly)
p.s. ............why yes i do :argh haha i am hoping that my car has a mis-machined head (the tsb you brought up in my other thread) ..that way when i come to the conclusion that i need a new head and cam and crank sensor i can convince myself that it will be the same amount of $$$ as a TT engine ;) haha and i will attempt to swap it out.
P3ngy
Car: 1994 300zx Twin Turbo(Sold)
1992 240sx (Sold)
Supra Swapped 95 E36 M3 - (Sold)
93 240sx (Daily Beater/Slider)
FlogWaffle wrote:
es.biggs wrote:..that way when i come to the conclusion that i need a new head and cam and crank sensor i can convince myself that it will be the same amount of $$$ as a TT engine ;) haha and i will attempt to swap it out.
Lots more in the TT swap then just the engine and turbos [: :facepalm:
es.biggs
^^ Pretty sure FlogWaffle knows that.
I just replaced my CAS with a used one from a local buddy, and it has worked great since then man.
