theoctopussi »
https://forums.nicoclub.com/theoctopussi-u79364.html
Tue Nov 06, 2007 6:06 am
dude, when the springs come out, give me a $100 bucks and I'll install them perfectly... I installed springs on 98 sentra, coilovers on my 2000 altima, springs my wifes 2006 civic, and springs on my last 2005 altima - none needed alignment. The only time you need alignment is if the parts are not handled gently and the geometry of the suspension is compromised. You're just lowering the stance of the car - the ONLY thing that will be affected is the camber and an alignment won't fix that.. But a little bit of negative camber is good for performance, PLUS our cars have mcpherson struts up from so they don't camber like a wishbone suspension would and the back has that multi link independent suspension so it barely cambers. on my last car, i did NOT have any uneven tread wear. Changed the tires ONCE because I kept hitting nails but that's about it... this is on a two inch drop. if you start doing coilovers with a lower drop then a nice camber adjustment will be WANTED but majority of coilovers come with a camber adjustment built in... and if you REALLY need an alignment because you're OCD like me LOL then I know a great place in Gardena that does it by hand and specializes in lowered vehicles. $70!
