According to the FSM (page ATC-91), the discharge air temp is a function of ambient air temperature and relative humidity. The 51F value you found actually seems to be pretty good. They give a range of 48-51F at 77F ambient to 62-68 at 95 ambient (50-60% RH)TDot wrote:OK. It so happen that I got a thermometer for my trunk, so I used that to test the temp out the vent. After 15-20 min the best I got down to was 51F if that helps you any.
