KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Mon Jan 30, 2006 5:37 pm
If I could step in here...
First off, that exhaust housing is pretty large for a streetable KA. There's just not enough exhaust flow to see the spool happen before 4k RPM and WOT at that.
Second, I've mapped out the T04E .46 trim compressor for the KADE and I'll be the first to say "RUN!!!" It's a very very sucky compressor for the KADE, and most likely this rings true for the KAE. It never shows any flow actually IN the center efficiency island, but rather on the right-most line of it, and only briefly (around 3500-4000rpm). After that, it shoots to the right and by the time you see max flow (lb/min.) you're only around 5500rpm and at somewhere around 50-55% efficiency. It's HORRIBLE. This was based on a pressure ratio of 1.87 (about 12psi). Max power at that boost level would be about 220-230whp.
I seriously recommend staying away from that turbo.
Oh, on another note, the twin scroll entry design is only useful if you have a manifold that is port matched to it (i.e. two runners to one hole, two runners to the other hole). If you use a standard T3 manifold with a single opening at the flange, you'll actually suffer from flow restriction at the turbine housing entry point.
