fabio420 »
https://forums.nicoclub.com/fabio420-u28809.html
Wed Aug 17, 2005 12:40 pm
Alright here's the deal. A while back this KAT blew. We didn't know what was wrong, so we rana compression test. The compresion started at 140 in cylinder 1 and decresed as we went back ending with 30 on the last cylinder. We ran another compression test after putting in some oil to check for the status of the piston rings. No change. So we took the head off figuring its a blown head gasket. the gasket had oil in it as did the spark plugs, and looked a little shredded around cylinder 4. So we rebuild a new head for performance( it was gonna get done anyway later) and swapped all the components in it. Finnally got everything in and put it back together. I used platinum spark plugs pre-gapped for temporary use(could get NGK right away). So after averyting was reassembled, we turned the engine over and got nothing. It turned and made the sound you'd expect, but almost with an uneven timed firing sound. Checked the compression and got 160,55,125,0. So I figure the rings or ring lands are gone. But I'd like to hear from people to make sure we're not overlooking anything. Please, we could really use the help. P.S. I really don't want to, but I'm afraid I might put dynamite up the exhaust if I don't fix this car soon.
