Your Maintenance List So Far
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
This isn't a space to discuss the maintenance/mods/installs/etc, please keep the subject-related chatter to the respective threads (use the search function). This is just a fun list to see who has changed the most parts, done the most service. If people start making this a dump thread for questions about mods - the thread will be locked!
PS: Please don't post if you washed/waxed your car LOL. That's not even worth posting! haha
30,000 - Differential Fluid Drained
30,000 - Transfer case Fluid Drained
30,000 - Cabin Filter Installed
30,000 - Trailer Hitch Installed
30,000 - Towing wiring harness installed
40,000 - New Battery Installed
45,000 - K&N Air filter installed
60,000 - Front Rotors Installed
60,000 - Front Calipers Rebuilt/Installed
60,000 - Front Pads Install
60,000 - Brake Fluid Drained
73,000 - Cabin Filter Replaced
75,000 - Spark Plugs Replaced
75,000 - Rear Calipers Rebuilt/Installed
75,000 - Rear Pads Changed
75,000 - Differential Fluid Replaced
75,000 - Transaxle Fluid Replaced
75,000 - Brake Fluid Bleed
75,000 - Engine Coolant Replaced
75,000 - Inspect & Cleaned Front Brake Pads
77,000 - SeaFoamed through pcv hose
77,500 - New Tires & Balance
91,500 - Differential Fluid Drained
91,500 - Transfer Case Fluid Drained
91,500 - Inspect & Clean Front Brake Pads
92,000 - Fan Belt replaced
92,000 - PCV valve replacement
93,000 - A/C compressor Electro-magnet & pulley replaced
93,000 - Front Right Lower Control arm replaced
93,000 - Front Right Hub Bearing replaced
93,000 - Front Right CV Axle rebuilt
94,000 - Front brake clean & lube
94,000 - Transmission Aux Fan install
94,000 - Rear Caliper bushings & dust seals replaced & lube (left & right)
94,000 - Front swaybar links replaced (left & right)
94,000 - Rear brake pads upgrade to ceramic (left & right)
94,000 - Rear Rotors replaced (left & right)
95,300 - EVAP Purge Valve replaced (p0455)
95,500 - Tie Rods replaced (left & right)
I installed GPS, led lights, led light bar, done tire rotations, used fuel injector cleaners, changed wipers, etc. I keep this list for anyone in the future who wants to buy my car, and would like to see service records. If anyone wants to challenge the validity of the list; I'd point them to the parts, this forum, or YouTube lol.
08roguesl
Car: 2008 Nissan Rogue SL AWD
2008 Nissan Rogue SL 78K
I have changed both driver and passenger cv axles.
Cabin/ Air Filter
Oil
Drive Belt..
All 4 Rotors/Brakes.
Is there anything else i should be doing to the car?
My mechanic said the transmission fluid is really dirty and needed to be changed... should i take it to dealer or have the mechanic do it ?
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
Did you happen to look at the list above by the OP? I would say that's a pretty good guide to answer you question about required maintenance, you won't find any better or more detailed response. Regarding the CVT fluid change, if you're ok with the risk and ensure your mechanic is using genuise Nissan CVT fluid he can certainly do the job, but I would ensure he only does a drain and refill, not a power flush for fear of damaging your transmission.
Return to “Rogue Forum”
