Milo (San Antonio) »
https://forums.nicoclub.com/milo-san-antonio-u61519.html
Wed Jul 18, 2007 5:19 am
1) Check the radiator support bracket for any bends (a common screw up is for people to jack up the car on the support bracket for the radiator, it is not structurally sound enough to support all the weight of the car and bends, this causes the hood/fenders to mis-align). Anytime I purchase a Z, it's the first thing I look at, it is very common due to mass amount of inexperience by previous Z32 owners.
2) Also adjust the rubber hood stoppers to align it a little better. May help just a bit.
3) If you also want to get savy and do a bit more adjustment, you can loosen the screws on fender to engine bay and you will get a small amount of adjustment on gapping from hood to fender.
4) Also you have a small bit of adjustment on the hood bracket bolts but I would only do that as a last resort, as far as alignment.
5) Lastly, you can adjust the hood latch by loosening the 3 (14mm I believe) that hold the hood latch on to both the upper radiator support bracket and the hoodlatch support bracket.
