encasemyheart wrote:Well, I'm picking up the Tial external gate for my setup, the 35mm, but I'm wondering about sound.
When the wastegate is active how loud is it? I'm talking about not plumbed into the exhaust, which I assume most of you don't do. I remember my DSM had a dump pipe and it sounded like the world was coming to an end, is this the same way? Or do most of you plumb it into the exhaust for a quieter noise?
Off topic: Will adding a fuel pump N/A cause any problems? I'm planning on installing all I can so when the turbo is ready to be installed I already have the whole fuel setup (pump, injectors, SAFC so all I have to do is install turbo, I/C, manifold, oil lines downpipe etc)
encasemyheart wrote:Yeah I know it can be done without a flex, but it puts alot less strain on the turbo housing, which when combined with the excessive heat over and over again can lead to failure. I just wish they weren't so expensive...
C-Kwik wrote:They aren't very expensive...
http://www.roadraceengineering...s.htm
FrEaK wrote:I'd guess by not venting it all underneath your hood your in some ways keeping the engine bay cooler...
This perhaps may be something to think about especially when going turbo.
Make sure everything is either heat wrapped or very vented with lots of air cooling...
silviaNE wrote:Do not install the larger injectors or upgrade the ecu till the you are going to turbo the car. Assuming you are not going to use a piggy back. If you are going to use a piggy back, you can install it now, just not the larger injectors, do you plann on using 370s?
FrEaK wrote:I'm not refering to that vent, as much as a vent for better airflow around your turbo and hotter parts...
The heat produced by turbos have been known to strip the paint off the hood from excess heat... wires have been known to burn from turbo heat... it's a precautionary measure that cant really hurt...
FrEaK wrote:Cooling is more important then people think, hell i'm not even going to buy a hood![]()
