you want it? you got it! arp part numbers for rods, head, AND mains!
Carl H
well since i had crap luck finding a proper part number for arp bits i had to go out and do some research on my own.
heres what ive found and is aplicable to the rb20/25/26 unless noted.
head studs:rb20/25 202-4301rb26 202-4207
rod bolts:z32 dohc vg30 bolts were reported to work on the rb25/26 but will not work on the rb20 (rod bolts are too long for rod, verify length of rb25/26 botls)pn for z32 rod bolts 202-6004use sr20 bolts, may need slight trimming 202-6005 x2 (2 sets req'd if using kit)or alternatively order (rod bolts and nuts respectively)12x ar3.67-112x n502rb20 rod bolts ONLY : 202-6003 (l24 late,l26,l28 rod bolts)
main studs:this is from my measurements of my stock bolts and my blockrb20/25/26 except rb30, again verify lengths and sizes.3x am4.600-1lb 11x am4.125-1lb14x 200-851914x 300-8344
carl
Modified by Carl H at 8:55 PM 5/18/2006
Joe
awesome.
thank you!
eh?
For RB25 rods, the arp SR20 rod bolts work fine. I didn't have any issues.
Carl H
said problem of vg30 bolts being too long on the rb20 rod... again keep in mind that if you choose to use vg bolts on your 25/26 make sure to get the dohc ones as the sohc is diffrent.
eh?
Not sure why you're d!ck around with VG bolts Carl, you're suppose to use SR bolts :P
Carl H
eh? wrote:Not sure why you're d!ck around with VG bolts Carl, you're suppose to use SR bolts :P
i was told that the vg bolts are what thaggard fits to his preped rods...
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
Awesome! Any part numbers for the ARP exhaust mani studs?
Carl H
kouki-gymkhana wrote:Awesome! Any part numbers for the ARP exhaust mani studs?
ask and ye shal recieve, i'll check back when i hear from the shop about my rod bolts.
gawdzilla
Car: none
eh? wrote:For RB25 rods, the arp SR20 rod bolts work fine. I didn't have any issues.
same w/ 26
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Sweet, FAQ material **cough, KAMIN, cough ** :D
-Dan
Sky80
Car: '92 240sx Fastback
^^^ +1
Carl H
ttt, rb20 rod bolts found, main post edited.
krayton
bringing this back up
what part numbers are these from?
3x am4.600-1lb11x am4.125-1lb
for the main studs.
cant find them in the arp parts list. i got the other 2 sets
Carl H
no idea what they are from, but if you contact an arp distributor they can order them as those are teh arp part numbers...
krayton
alright, thanks carl.
they arent showing up in the catalog, but you can just call the arp for them. they gotta be dropped shipped too
GTR Shop
Car: 180sx RB26 T78, Y31 Gloria VIP + HEAPS of GTRs!
Head studs are wrong for RB26.26 uses bigger stud.
Carl H
GTR Shop wrote:Head studs are wrong for RB26.26 uses bigger stud.
you sure?those are the p/n's direct off of ARP's website...
BoostFab
Car: S13cp, S13fb, S14z
i can confirm on the RB20/25 ARP head-studs p/n: 202-4301i have the box sitting right in front of me here.
as for the rb26 p/n: 202-4207 is correct.
good information carl!
TachPHD
could someone clarify the last part on the main studs? are the last two the p/n? i was confused. sorry. thanks
"main studs:this is from my measurements of my stock bolts and my blockrb20/25/26 except rb30, again verify lengths and sizes.3x am4.600-1lb11x am4.125-1lb14x 200-851914x 300-8344"
Carl H
the last 2 are the part numbers.the first 3 are the count so 14 of whatever...
