Hey Greg,
Thanks for the warm welcome. I'm up in the north bay. Your right about the bay area dealerships, they are expensive! The closest to me is about an hour drive away. And after reading several of Q45 tech's posts regarding common dealership practices, I have steered away.
I am a complete maintenace freak....and finding this sight was great, as I have learned so much. Here is a list of what I have done to date:
1.) Full 60K service @ 60K2.) New Brakes front and rear....pads were fine but rotors were warped bad. Couldn't take it any more. My fault though, due to high speed braking when I first got the car. I could not belive the way this thing accelerated through 120mph!!3.) New front struts - I went stock, mainly out of ingornance. I did all the above prior to finding this site. I would have replaced all the rubber and gone with tockico blues. And saved money. 4.) Replaced all belts5.) From the moment I got my Q I have changed the oil every 3-4K using only 5-W30 mobil 1. I also use a K&N oil filter, what do you guys think about it?5.) After I found NICO....I checked my power steering fluid and it was brown just like anohther member, so I did the turkey bastor thing about 6 times with transmission fluid, and now it's nice and pink.6.) In reading Q45 techs post I realized (after closing look at my 60K service invoice) that most of what I thought had been done, had not! All the cheap short cuts were used.
Never going back there! And I have found a honest Tech.7.) At 78K I had the transmission flushed....as the 60K service just changed out 4 quarts.8.) Yesterday, @ 85K I had the pan drop, new filter, with Mobil 1. A new battery, and air filter. To my knowledge the pan had never been dropped so I was very anxious to see what she was holding. You guys would not belive how clean my pan and filter were!!! There was nothing in my pan at all....the magnet had maybe 1/16 of the finest black metal shavings I have ever seen. You should have seen the smile on my face.9.) Oh I almost forgot the dealer put S rated tires on my car. I couldn't belive it. So I got a set of Yoko 550's or something like that. I went with 225/60/15 stock load rating, tread wear is high @380 but I use the Q for commute. All highway and she loves it.
Any suggestions would be great!! I want to do a throttle body cleaning. But am wondering if I really need it? The next thing I'm going to do is some suspension work. I think my uppler link passenger side is gone. I can feel it pop when I back up out of a parking spot. Does that sound right to you?
Thanks again,Robert
